Installed a Montana Fab AW4 Override Switch. Now I can have 2nd when I want it!
Man, those look sharp. I am in the market and I’m thinking these will be best but I don’t wheel really so I’m also thinking those might be overkill. Also considering Rubicon express. But those Fox’s look hot
Evap problems on the two door. Maybe I can get it fix eventually.
Coolant reservoir issues on the four door. Replaced with a factory replacement.
I replaced that same pump and gasket a few months back and fixed mine right up. Hopefully that's your issue as well.
No. Just have a CEL and need to get it smogged to get my registration stickers that I paid for back in June. Lol
Ahh... No skid plate?I was going to do just that but my evap is all beat up. Thinking about just replacing the canister also while I have it out. Need to see if the dealer has one tomorrow.
Replaced the driver side knuckle. This is what the old one looked like. Thankfully Ed (Brute) came to the rescue and sent me one from his stock. Thanks again!
Does it have anything to do with the muffler being right beside it? Hope not as I just did that
Shit, I still can't believe how bad that is and that you didn't really feel anything loose. [emoji33]
Install the new ball joints while you were at it?
You're a brave man. I the oil pan and evap skids were among my first mods.Nope. I don’t have any skids besides the ones that came from the factory. Not even oil pan. [emoji15]
I’m so thankful I didn’t have a catastrophic failure. I also discovered that the nut on the lower passenger side ball joint was really loose. Tightened that up at the same time that I replaced the driver side knuckle.
I ended up ordering some Rancho knuckles after seeing some of the carnage my tie rod has endured. When those come, I’ll do a front end refresh. Install the prosteers and new knuckles, raise the PSC ram tabs on the TB bracket, and fix whatever else needs tidying.
I may not have time for all this until March. Until then, Ed’s knuckles will see me through.
