Cut fenders
New decal
Half inch spacers to level out the front.
Like those spacers! What brand did you go with?? Was it an easy install?? I've been looking into getting some! Thanks
-Big E
I had the teraflex spacers that came with my lift. I didn't install them when I did the lift and the rear was a little higher then the front. No difference in ride though.
-Big E
I had Tera flex spacers on my rig just took them off for my lift but spacers are very very easy to install. Just unscrew swaybar links from the axle don't have to fully remove them , do the same for the shocks and unscrew the bracket that holds ur brake lines so they dont break when you drop the axle ,make sure ur frame is on jack stands and have a jack to hold up ur axle now just have a buddy press down on the axle till u can slide that spring out than lube up the spacer slide that on then ur factory spring isolator and put ur spring back in. Reconnect your shocks and swaybar links and your done. My advice is dont hook up swaybar links or shocks until both sides have the spacers and springs installed will make life easier. Hope that helps.
Sent from my JK
Thanks man I really appreciate it!! Seems easy! Do you have any pics of your jeep when you had them on??
-Big E
Sure do all I had was 1" spacers just in the front to level it out after the winch and it looked sick everyone thought I already had a lift
That's stock
After spacers
That's stock with 1" spacers in front after I cut my stock fender flares
Here is my jeep now until I can finish the rear if my lift tomorrow
Sent from my JK
Sweet man thanks for help! What kind of lift did you get?
-Big E
When it comes to coil spacers, just get the cheapest you can find used. There are no "top quality" spacers out there. Buy used to save a few bucks, they are nearly impossible to damage.
4 of 6 A-series rock lights in today the other 2 need brackets fabricated before they go in!
Put on some seat covers. Damn leather takes forever to clean after dusty trails. Drilled out a broken bumper bolt. Re-hooked up rock lights to new rear bumper.
holy moly! do you think you really need 2 more? that is bright as all get out!
andrew -
