Bullwinckle
No picture but got my bomber rockers in from Evo.
Super fast shipping ordered on the 23rd and received them today! Now to find a local powder coater.
I love mine!!Started on the long arms and decided it was time to get some better jack stands.
Very nice! Those are the ones I’m looking at also.
I picked a set of those up last month. Heavy duty for sure.Started on the long arms and decided it was time to get some better jack stands.
Very nice and yes a must have and I love mine. Make sure if you take the riser off and use the jack with just the Pro Eagle base plate you don’t bend the tabs that the riser twist into. Either buy a thicker rubber pad when using the jack without the riser or be careful where you place the load on the plate. If those tabs get bent really bad you can't twist the riser into place. I had to use a pry bar to bend them back slightly. I ordered a thicker rubber floor jack pad off Amazon when going back and forth between the riser and base plate. It is really nice not have to stack block anymore LOL.With the new coilovers this is a must have. Pro Eagle 13"extension and pad. Expensive but very much needed. You can see the stack of wood I was using, bad idea. Also got my nitrogen tank and regulator all set up.
View attachment 365633View attachment 365634
Which regulator setup did you go with for the N2?With the new coilovers this is a must have. Pro Eagle 13"extension and pad. Expensive but very much needed. You can see the stack of wood I was using, bad idea. Also got my nitrogen tank and regulator all set up.
Yes it does with most jacks but not all. You need to buy the riser and lift pad separately and can adapt it to your jack.Probably a dumb question, but do those jack extensions bolt into the jack cup? Haven’t seen those before. I like it.
Nice! I'm loving mine!The KC lights for the my JT’s front bumper arrived today.
How long did you wait ?The KC lights for the my JT’s front bumper arrived today.
Ordered 6/20. Delivered today.How long did you wait ?
Flex Era 4’s. Getting hooked to the switchpros.Nice! 4" right? Are you going to wire them to the factory fog light switch?
Are you keeping those bezels or going with a different color?The KC lights for the my JT’s front bumper arrived today.
