Replacing the aluminum steering knuckles with a set of iron ones is an upgrade that I highly recommend for anyone who owns a Jeep JL Wrangler or JT Gladiator. And, if you spend any time out on the rocks, there is a real benefit to installing a set that will also located your tie-rod, drag link and even steering stabilizer higher up and out of harms way. Of course, if your Jeep is lifted 3"-6", correcting your steering geometry will help improve your handling as well and in this video, you'll get to see what it takes to do all that and with a High Steer Knuckle Kit with track bar relocation made by Rock Jock 4X4.
TOOLS YOU'LL NEED
• 8, 10, 13, 17, 18, 19, 21, 22, 24, 35mm Sockets & Wrenches
• 12 Point 13mm Socket
• 5/8, 1-1/2, 1-3/4" Wrench
• 1-1/2" Crows Foot
• 22mm Crows Foot
• Torx T-30 Bit
• 1/4" Allen Bit
• 5, 6, 7mm Allen Wrench
• Ratchet
• Short Ratchet Extension
• Long Ratchet Extension
• 1/2" Drive Swivel
• 1/2" Drive Ft. Lb. Torque Wrench
• Pliers
• Vicegrips
• Small Screw Driver or Punch
• Floor Jack
• Jack Stands
• Pry Bar
• Rolling Head Pry Bar
• Dykes
• Big Hammer
• Blue Loctite
• Red Loctite
• Drill
• Center Punch
• 1/2" Metal Drilling Bit or Unibit
• Grinder
• Flap Disk
• Safety Glasses
• Tape Measure
• Ratchet Strap
• Grease Gun
RECOMMENDED BUYS *
RockJock High Steer System for Rubicon: https://amzn.to/4hCIoFa
RockJock High Steer System for non-Rubicon: https://amzn.to/4bywqv0
Alignment Guide Plates: https://amzn.to/3Qso7XV
1/2" Impact Wrench: https://amzn.to/3WNeYLE
Drill: https://amzn.to/4iiUQuX
Grinder: https://amzn.to/4ip9BMu
3/8" Ratchet: https://amzn.to/43F2KqO
1/2" Ratchet Set: https://amzn.to/45JrvnD
1/2" Swivel Socket: https://amzn.to/3WYzkBR
1/2" Torque Wrench: https://amzn.to/42ihtqt
3/8" Ratchet Set: https://amzn.to/42rsGoK
22mm Crows Foot: https://amzn.to/3XYoVI1
Large Crows Foot Set SAE: https://amzn.to/4bBfrIo
Allen Wrench Set: https://amzn.to/3FAnVn7
Torx Bit Set: https://amzn.to/4icophM
Center Punch: https://amzn.to/3Fu3OXF
Unibit: https://amzn.to/4bBeQq8
Pry Bar Set: https://amzn.to/3Cu6S1v
Rolling Head Pry Bar: https://amzn.to/3CdXdvH
Vice Grips: https://amzn.to/43pmsXS
Tape Measure: https://amzn.to/3OQGaaB
Floor Jack: https://amzn.to/3CiV1Tv
Jack Stands: https://amzn.to/3MSOLqu
Grease Gun: https://amzn.to/4hiWSdp
Grease: https://amzn.to/4iPMzOQ
#jeep #highsteer #rockjock4x4 #wayalife #jeepgladiator #gladiatortruck #jeepjt #jtjeep #jeepgladiator #wrangler #jeepwrangler #jlwrangler #wranglerjl #jljeep #jeepjl #highsteerkit #steeringknuckles #trackbar #draglink #currectlync
* Please note that purchases made through the affiliate links will help to support this channel.
TOOLS YOU'LL NEED
• 1-1/2" Crows Foot
• 22mm Crows Foot
• Torx T-30 Bit
• 1/4" Allen Bit
• Ratchet
• 1/2" Drive Swivel
• Pliers
• Vicegrips
• Floor Jack
• Jack Stands
• Pry Bar
• Dykes
• Big Hammer
• Blue Loctite
• Red Loctite
• Drill
• Center Punch
• Grinder
• Flap Disk
• Safety Glasses
• Tape Measure
• Ratchet Strap
• Grease Gun
RECOMMENDED BUYS *
