View attachment 233954Looks like I'm good for that 100+ mph bombing through the desert!! Woo-hoo!!! Notice my strategically mounted front plate/deflector push-down wing? Keeps my front end from lifting off the ground at 103mph and up! [emoji6]
this is what it looks like AFTER it has been moved with the relo-bracket.There are a few kits that relocate the vac pump up near the master cylinder/break booster area. I would go that route to be sure it's outta the way completely. Just google "jeep JK vacuum pump relocation". I used the bracket that just turns it sideways. It worked for me, but only because I knew it would ahead of when I did it. View attachment 234029this is what it looks like AFTER it has been moved with the relo-bracket.
Anyone with the EVO vac pump relocation...can you confirm that the pump is moved behind the sway bar? That's what it looks like in some pics I've found.
Overall "build thread"
http://wayalife.com/showthread.php?26097-I-guess-it-s-the-quot-Super-Stocker-quot-build
This is correct. I didn't get the vacuum pump relocation bracket this time, I just zip tied it under the hood! LoL!
That turned out great though!!:beer:
Do you even wheel, bro?!?! I hit at least 101.1 in the AZ desert! [emoji23]
That turned out great!
The top mount winch keeps me limited at 100!:cheesy:
