What did PSC say to do with the resi hoses? Does it require more cutting to the stock box? Did they not tell you how they mounted that way?
So did you actually end up cutting into your air box like PSC shows or did you find a way around that?
sucks no one has come up with a good spot for that yet that isn't a ton of work, one reason (other than funds) why I have been waiting to upgrade but I do think I could really use it after getting my wheels stuck a few times now when I need to turn.
View attachment 123838View attachment 123839
I used the aFe air filter and no modifications were needed for placement of the PSC reservoir.
It runs straight down just in front of the axle.I like the simple mounting bracket you made to bolt on the billet PSC bracket/clamp. Looks great and allows you to rotate the reservoir.
Where did you run the vent line on the top of the reservoir to?
All the options out there and you went with the one that has been proven to allow dirt into the motor. Lol
It's temp till the hemi swap. It's only money and now it looks cool.
I'm sure TTFHell can attest that his engine ingested copious amounts of dirt and not casting sand. But you'll be fine with as much as your vehicle hits dirt.
I would suggest adding some trim to the heat shield so the lines don't rub through. Looking clean tho :thumb:
