Yeah, that's a bit more than the $60 I spent :crazyeyes: The bushings I'll have to press in, but the ball joint is in the bracket already. I guess I'll still have to press it into the a-arm though. I've got a little shop press that should work though.
Oh, and most of the spacers I'm finding are for 3" or more, so unless I make my own I'll just be going without.
The ball joint pressed into the bracket is how most of them come. You bolt that right onto the rear pumpkin. Then the arm has a tapered bore on it that slides over the ball joint stud, then you put a nut on it from the top. No press needed.
As far as the bushings, yes you will have to press those onto the arm, you will have to pull the arm from the vehicle to do it. Just look at the old bushing positions carefully. They only go one way because the arm flexes one way. Something like this because the center sleeve isn't perfectly round, it's squared off on 2 sides:
Yeah, they're 100 bucks. You could always get it back on the ground and take a look at the angle and then build one later if it's too steep.
Well, while I'm waiting for parts to come in for the rear A-arm I thought I'd look into the voltage leak some. I hooked up a meter between battery positive and the fuse box and initially it was a 1 A draw (I was like WTF!?) but then it leveled off to about 300 mA. It still seems a little high though. The weird thing is that it seemed to fluctuate from there. Sometimes it would drop down to 20 mA without me changing anything... The only real result I could get was when I pulled the #7 fuse (SKIM/hoodlp) in the cabin JB. Then it would stay consistently low. No lamps seem to be staying on and there is no hood lamp that I can find. The Jeep starts and runs fine so I doubt the SKIM is malfunctioning. I'm planning on taking the battery to be tested too, just because all of this draining may have damaged it a bit. Still no great leads though...
So I decided to plug the OBD scanner and see if it had any info for me. It pulled a trouble code, but I've had no CEL and it was a P0740 (Transmission - Torque Converter Clutch Circuit). So now there's another seemingly unrelated problem. Jan is turning into a real bitch.![]()
Probably good advice. I'm just going stir crazy waiting for the parts to come in I guess.740 could be related to the actual TC itself or something in the valve body. Being that your cel wasn't actively on, if I were you, i would clear the code and not worry about it too much. Just monitor it for now.
That'll do it. Was it hard to get the arm out? I know with rust it can really be a PITA.
Got everything pressed out and ready. There was a little surface rust so I did a quick grind/sand/paint. Parts are now showing delivery for tomorrow!
Good on ya, mate! Nothin' like a day down unda workin' ona boomerang!
Glad you got it back together. Any visual rub marks on the rear shocks or sway bar links? You'll be happy with the spacers regardless. Really makes the wj stance look great, IMO.
The sway bar links are inside the shocks, what would they be rubbing against?
Edit: It was the shocks, not the sway bar links.
