I've had some trouble with Jan having a inconsistent idle while in park/neutral so I took a look at the throttle botty and found that the IAC module was pretty dirty. I cleaned it up with some TB cleaner (and the throttle body while I had it open) and she's got a perfect idle now! Gotta love an easy fix.
Here's the IAC before cleaning, pretty gunked up:
I didn't get an after, but you can always Google WJ IAC if you want to see what it is supposed to look like (metalic and shiny).
Very nice looking WJ. Looks extremely clean! Good luck, and congrats on the third child! :thumb:
Very nice WJ.
Nice looking build and great to see another addition to the WJ Army![]()
I've done that as well on mine. Does the trick.
Looks good. I had a voltage drop on mine as well. Ended up being high resistance in the end of the positive cable. Hope that fixes yours.
The last of Jan's new goodies are on the FedEx truck! They had to break it all into multiple shipments and it's been trickling in over the past month so I don't have tracking infoHopefully I'll get to start the work this weekend; if not then it should be next week.
Also, it looks like the new battery terminals fixed my voltage problems whoop whoop!
Glad the voltage drop is fixed. What other stuff are you working on?
New OME coils and Rancho 9000XLs![]()
How high are you lifting it?
So I went ahead and started, but I got a nasty surprise. I haven't worked on WJs much, but I'm pretty sure the spring perch shouldn't look like this:View attachment 270203
Or this:
Not really sure what to do at this point...
Not normal, but sadly it's common. Clayton is the only company that makes a rebuild kit that I know of, I'll try to find you a link.
https://www.claytonoffroad.com/jeep_grand_cherokee_coil_mount_repair_kit_1999_2004_wj
300 bucks. May be better to diy it if you can weld. He'll you may be able to get a used axle for that.
Thanks, I'll probably see if I can work something out to fix this one. Maybe some 0.25 steel and capped pipe to get something like this:
Then I'll have to borrow a welder or finally spring for one for my garage. I can't even count how many times I wished I had one...
