Thank you Brick for the pre axle dump exhaust parts!
I’ll tear into that this weekend
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Changed the oil and Changed the Diff fluid today. The ring on the 13 bolt is massive!
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Do you guys have regulations on required signs? I know here in Illinois or Missouri that is not a regulation sign so I would completely ignore it.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
I should probably know this and can go look but did you have to remove the cover? Assuming all looked good during the change?
In Colorado, any PRIVATE business that posts a sign not allowing firearms is well within their legal rights not to allow them in their business in this state. It is illegal for a public place to do the same though. Any PRIVATE business that doesn't welcome law-abiding citizens to carry guns, I tend not to do business with. If they don't want defense against criminals, that's their legal choice. Regardless, I'd much rather support a business that allows the open or concealed carry of firearms. If a legal CCW holder visually sees the sign and is carrying at the time, it is illegal for them to enter the building while still carrying.
How many miles on those axles? They look brand new.
Do those axles use gaskets or do you use gasket sealant?
600. I’ve always swapped the fluid 500-600 miles on a new set. Might be overkill, but for what I’ve invested into them it’s cheap insurance and I can check everything over to make sure it’s good.
Good old RTV. I didn’t line it up right in the bottom of the front and had to yank it and redo.
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Is there any chance you can bust the bottom of the rear where they shave it, it looks really thin
Huh? Are you posting on the right forum?
Get yourself a couple longer bolts the same size as the cover bolts and cut the heads off. Use as guide pins.
