Stock "cage"???
HDGasser
Sooo how well does a stock cage hold up in a rollover?? Not a 60mph barrel roll but just a trail flop?? I understand they have to meet certain requirements that have to be met in order to produce them from the factory but with MOST of us here having added a significant amount of weight to these things how do they do??
I really DO NOT like the fact there is no C pillar in these things protecting people inside... Huge weak point IMO. More importantly my kid. I have no plans on rolling this thing with my kid in the back but then again I don't think anyone does but again shit happens!
Is Poison Spyders c pillar kit worth it?? Or should I just man up and cage the whole thing and be done with it.
Are the bolt in kits strong enough? Or am I going to be striping my JKU and welding in a cage.
the bolt in cages, whether you go with RockHard, ORFab or Poison Spyder are great insurance in case of a flop or slow roll. The Poison Spyder C-Pillar support can be added with or without any of the above mentioned bolt-on sport cages.
I got the orfab cage and installed it a while back and am having a lot if trouble getting the the front corners of the header with my trex top to be air tight . I set the windshield back to the exact measurements. So not sure where to go from here. Other than that the cage is great.
andrew-
Any gain in going with a Synergy weld in cage setup over a bolt in setup?? Obviously the welding part but strength wise??
I like the design of the PS one myself...
Yes!! My next question! Any interference with say a trektop NX??!!
Not sure if mine is installer error or if it does not work with trektop. Have not had time to call orfab. If I were to do it over I would of went with the rockhard.
Stock cage is probably fine in a flop.
Sport cage is better than the above.
Full weld in cage tied into the frame better still.
All depends on your individual comfort level/budget. I think Eddie has posted on here before he has seen rollovers with a sport cage and they worked fine.
I run a Rock Hard sport cage and the PSC c-pillars in the rear for the reasons you mentioned. I'm not planning to change this set up anytime soon.
there will be a strength gain by going with a framed tied in weld-in cage, but this application is overkill for most.
