So I am going be upgrading my steering stabilizer while I am installing my new steering components, and I keep reading that getting one with the pass-through body is recommended, but I found a couple from Fox and I am not sure which would be more applicable to my own needs. So there seems to be 2 grades, one being the standard one and then the ATS one
So I don't plan to go over 3" of lift anytime soon and I won't be going over 37" tires. So would the TS (and cheaper) option be enough? Or should I pull the trigger on the ATS stabilizer in preparation of the eventual coilovers in the next couple years? Will the coilovers even make a difference if my tire size doesn't go over 37"? Do I even need either and would a closed shaft bilstein 5100 steering stabilizer work well enough? Thanks for any info, I appreciate you all.
