.These are 315 Duratracs. Here is completed install of the lift sitting on level ground.
I am going to have to address so minor rubbing (even just on the street).
My lower air dam runs at full turn, that's an easy fix. I'm sure I'll get some fender rubbing too.
I'll pull the air dam this morning and cut the Rubi rails back. I might trim the fenders today too. On that note, does anyone know if you have to use anti-flicker harness of any kind for the side marker lights? Or is it just positive to positive, negative to negative?
View attachment 270501.
Looking good! Bout time you got that thing on some bigger meats :thumb:
Nice sharkey!
For the side market lights it's just pos to pos and neg to neg. what marker lights you installing?
I don't know yet. I'll probably either buy some eagle eyes off of Amazon or get the KC disc lights here locally.
Looks like you've got some wheeling to do.
Looks like you've got some wheeling to do. [emoji41]
No need for any resistor on the side turn signal lights (assuming they're LED) if you're tied into the front turn signal wiring. The front marker bulb is sufficient as a resistor so you won't get any rapid blinking.
