Sharkey
Word Ninja
Shark "Tank"
It cooled off below the temp I set and then slowly worked its way back up to within a couple of degrees. I'll need to test it better with an internal thermometer.
is your ARB temp accurate? does it shut off at your setting?
the one I received appears to be 10deg off, I set it at 37F the ARB doesn't kick off until it reaches 27, I set it to 41 and it kicks off at 31.
I need to get an internal thermometer to see what the actual temp is.
