StrizzyChris
Also I have had a few questions about the swaybar relocation. I am terrible at descriptions so I used my crappy paint skills to help me. If you see in the pic below the #1 tab(original mounting location) on of the swaybar housing is thin. Its sole purpose is to attach as the anchor point of the housing to keep it from spinning freely. The #2 spot is a hole that has a bolt in it from the factory and holds the housing together. The reason you will need to drill this hole is because #1 hole bolt that you will now be inserting into the #2 hole has a short threaded section and the body of the bolt(In the circle) is larger. The larger bolt body will stop you from being able to thread it completely into the swaybar housing. By reaming the #2 hole by 1/2" this will allow you to thread the bolt in far enough to slip the un-threaded section in far enough to also secure the 2 parts of the housing together. (I hope this all makes sence)
