This was very informativeFour Wheeler magazine just posted an online article regarding recovery that I found worthy of sharing.
http://www.fourwheeler.com/how-to/tech-qa/1601-top-10-trail-recovery-no-nos/
Great article! I agree with everything.... BUT
Linking two straps together with a d-ring is extremely dangerous and is cause for more than one wheeling death over the years. Two straps should NEVER be put together using a d-ring, if that strap was to come off the tow point or if a strap was to break that d-ring is going to become a projectile potentially killing someone if it hits them! Google it, I am sure you will find stories!
The best way to put two straps together is with a wooden dowel or stick, hell even a newspaper stuck in between will work
Happy and SAFE wheeling!
Jeff
Have a couple noob questions. Back a ways, it was mentioned to criss cross the rope while winding it on the winch (after the first layer). Is that only for synthetic rope or wire too? Hopefully will be getting a winch before long. I know it has to be wound under a load. Most likely will be getting steel rope due to funds unless I can work synthetic into the budget and wondered what the proper way to wind it up would be.
Thanks.
What about a high lift Jack? Anyone find that necessary?
WTF! The roap or strap your using can become a projectile! If jurked hard enough and broken. The majority of my career is revolved around rigging. Picking and pulling loads from any angle an sometimes many blocks with multable parts of line to gain mechanical advantage and I can assure you we never put a piece of wood or newspaper to link two straps together my friend. Of course you can do anything in a bind but that is deadly advice!
Hmmm let me see should I use this 3/4" shackle that I've got to that's rated at roughly 5 tons (can't exactly remember off the top of my head but it says on the shackle) or ya know fuck it I'm gonna use this branch that I found here on the trail to attach these two fiber slings together.
"Necessary"? No. That's why it's not on the list.
I used to want one of those. I did some research and realized I probably shouldn't get one till I have some teach me, in person, how to properly use it. Those things can be pretty dangerous from what I read.
Okay, here's another one that people who take courses and get pamphlets will say that I'm wrong about and ya'll can take it for whatever it's worth.
1. Attach your synthetic line to the drum and then wind it in nice and neat orderly lines for at least 10 loop or even better, until the drum is completely lined.
2. Apply a 6"-12" piece of duct tape lengthwise along the line from the drum out. This will help you to know that you are at the limit of what is safe to let out.
3. From here, continue winding in your line but NOT in neat orderly lines but rather, at an angle so that as you work your way back and forth, the line will be crisscrossed.
While this will not look as pretty, it will prevent your line from biting down through the wraps.
Please note, I have not taken any courses, have not gotten any pamphlets and certainly have not taken an exam where you either pass 100% or fail. This is just something that I've learned over the years. You can take it or leave it. :yup:
