Got few little odds and ends done yesterday. First, I got around into installing JKS spring retainers.
Had to tape the nut and the washer to a wrench and feed it through that little opening beneath the spring perch. I jacked her up and got some jack stands under the frame to take some tension the coils so I can stick my big hands inside the coils.
What a major pain in the ass it was to get those on. I can't believe I got the bolt started on a first try, I attempted this earlier this week with no luck at all just lots of cussing and throwing wrenches around lol.
Here's all done
I also have these JKS spring brackets which I scored at a good price form JKbrick, thanks Mark. Unfortunately they won't work with my AEV track bar bracket, I guess I will need to get JKS track bar bracket too to make it work. Probably also their adjustable track bar.... more [emoji383][emoji383][emoji383]lol. Anyhow, I decided I'll just try the retainers for now and see if that keeps my springs in place. Just need to find a spot to flex her out which is a challenge around here.
I think I'll be ok with just the retainers on the axle, even if my coils do become loose and unseated at full droop, there really isn't too far for them to go. Looks like the lip around the spring buckets up top will stop the them form tipping over.
Second, I finally got around to adjusting my E-brake. Both wheels and calipers off for this.
Once I pulled the caliper off on passenger side a decent size rock fell out of somewhere [emoji848], I have no idea where it was stuck but I guess it's good that it's out
Anyway
Through that little hole, with a brake spoon to get to the adjustment screw.
I just went as tight until I couldn't spin the rotors by hand, and then back it off a little so I can spin em by hand with some pressure. Fairly easy to do, just time consuming and a little of a pain in the ass.
Last but not least, I looked into adjusting my steer stops in the front.
The whole time I own my jeep I was under an impression that the adjustment bolt is welded In place. I finally looked it up online and came across Eddies write up on it..... lol it's only the nut that's welded to the bolt and not the whole thing welded to the knuckle lol
I added some washers to stop my turn. I need to got longer bolts as I have bring the stops out further than I thought. My brake lines were getting dangerously close to my offset shock/bracket. Also I can't figure out what was stopping my wheels front turning as it wasn't the stop bolts at all, I was suspecting my steering stabilizer biding against the track bar bracket, but I am not sure if that it anymore. I think it was just going as far as the steering box allowed it, making a weird wine at full turns. I got that fixed to some degree, I will have to look into this a little more.
Hard to tell on the pictures but with up travel my shock body will be very close to my brake line, especially when wheels are turned.
I need to find a spot to flex her out and see how everything clears, also hopefully a trip to off-road park next weekend
[emoji869][emoji108][emoji106]
Sent from my iPhone using
WAYALIFE mobile app
