I do not have any experience with either as yet. but for what its worth I thought I might tell what I have planned.
My Jeep is a customized 48 CJ-2A I'll be running 8.50 x 29 tires off road and P235/75-15s on road.
In the back of the Wheel Houses where the Military Jeeps in WWII had a pair of tool boxes the Civilian Jeeps have a empty space. On one side unless removed is a brace that goes from the top of the Wheel House to the inner wall and the Rear Side panel this was to help support the Spare tire mount. A few (about 10K of the 48's this was on the left) the rest it was on the right. I happen to have both braces in my customized Tub. This give me plenty of room for a Pair of 1.5 Gallon Aluminum Air Tanks mounted vertically with nice water drains at the bottom. I plan on setting up a Compressor either on the right inner fender or possibly on the back side of the Riser between the front and rear floors. I will run a line with a QD to the engine compartment as well as between the seats and then I have a Connections box in the back (with a 7 pin trailer plug 12 V 50 amp connector 120V outlet and an Air QD.) Granted even at the possible 200PSI I could put into the tanks (they are rated 300 PSI) I know they will only help the compressor air up a flat or run something. But they will also pressurize the water tank in my Off road trailer (I'll use a regulator).
If it were not for being able to "hide" the 3 gallons worth of Air tanks in a place in the Jeep I really wouldn't be otherwise able to use I think I would go without Air storage completely. Since the cargo area of a 2A is tiny 35" x39" hauling around a CO2 tank would be a PITA.
