JK's JK
Banned
No stock axles brother
Lucky guy. :thumb: Congrats on the new setup :yup::rock:
So I heard the Tcase shift knob is no longer being made happen to have any left? I really want one!
Sent from my LG-D800 using WAYALIFE mobile app
Ha ha. Phase 2.
- Jason
Hi Guys,
Do you guys have pictures of the rear brackets that are welded to the frame? Looking for high clearance lift and the DD. Trying to figure out if I welded on the EVO sliders will the rear leg be in the way.
So is it possible to run the high clearance brackets without coilovers? I see you have them in the picture, im just curious.
YEP!!!! :yup::yup::yup:
Seriously? Did you not read a single post in the other fucking thread?
only Off Road Evolution CAN do it for you.
let me also note that running the high clearance with shock/coils, you run into a potential travel/clearance issue and it is not recommended. the DD is a great kit and will work for 99.8% JK owners who are looking for a long arm kit. the high clearance is designed to work with the DTD and has to be modified (once again only at ORE) to be used with any other system.
from left to right...
EVO MFG Front DTD axle saddle (D60)
EVO MFG High Clearance Long Arm axle mount
D60 Upper Control Arm - Reinforced The ORE Way!!!
