Mybadjk
Damn man. Its been giving you fits lately. Glad your working through it though
aka cavfighter
Yeah she’s being a brat lately. Lol
aka cavfighter
So experienced death wobble for the first time. Made a turn and was getting up to speed and hit a pot hole. Doesn’t help having bad ball joints, and bad upper control bushings. Axle side track bar bolt was loose as well.
I’ve had the replacement synergy’s for over a week. Just been working and too cold to install them. Replacement axle upper control arm bushings will be here tomorrow.
Good luck fixing it.
I think the big problem was the loose trackbar. Has been far so fine
Upper control arm bushings can be a bitch to change since they are pressed into axle side. How did you figure they are bad? I am having a slight intermittent shimmy I am trying to pinpoint, very annoying.Well went through and re-torqued suspension. All the bolts on my discos were loose as well. Did my ball joints. Jeep feels a lot better. Just have to do upper control arm bushings.
Edit: unless the bushings on the frame side are bad.
I think they make Johnny joints you can press in there. I’m assuming with a ball joint press?
VeruGE*144 said:Upper control arm bushings can be a bitch to change since they are pressed into axle side.
It's almost impossible to tell if they're bad visually unless you pull the arm off. Most of them won't wear out until around 100k+ miles. One thing I found works, if you set up a camera on a tripod and record the bushings while you get in the jeep and power brake it. It will be obvious is one has failed.
JKBrick said:I think they make Johnny joints you can press in there. I’m assuming with a ball joint press?
Great idea, I actually have a GoPro with bunch of mounts. I can mount it up down there and go for a spin
