I have 3 new tires coming today. I'm pretty sure these tire have only 6000 miles on them and are badly wore on the outside. I'm thinking it's probably from to much toe. What's your guys opinion?
Toe being off would cause that kind of wear.
It's either camber or toe issue. Usually with toe, you can feel a feathering on the edge when you run your hand across it, however, it's not as noticeable on mud tires because the lugs are so far apart from each other. Post some closer up pictures of the edge wear.
Yup, you should feel or even see some feathering especially if it's toe. Camber isn't as likely on a solid front axle or at least, not on the outside.
Ok, great Im sure that's what it is. Without me doing a search can anyone tell me how much toe I need with 40's?
For me, I always try to get my toe set at about 1/16" and no more than 1/8" regardless of tire size.
Aww thats a bummer! Defenitly understand about the space they take up and a clean garage!I thought about that, but im trying to get my garage cleaned out and they were a lot worse than they looked in the picture.
Is it normal to only get 6000 miles from a set of Trail Graps?!
Hell, those didn't even make it to one rotation! :crazyeyes:
Are you sure you're measuring right? If you really are 1" toe out, you would totally be able to see it - no question about it.
That's what I was thinking but I have check where I'm measuring from twice and I have it the garage where I can't step back and take a good look at it. I think I need to walk away for a little bit. Do you think it's possible with the tie rod as short as it would go
Yeah your right. I pulled it outside side and it looks like it's toed in. I'm trying to tape the tape measure and do it myself, not working to well. Thanks for the advice and I have evo's high steer.
