highoctane
Yeah was really happy when I saw them. No, there not arb, just go to crown performance and they have different sizes and custom sizes too.
You remember what sizes you ordered?
I ordered 216 inches for the rear and I'm not 100% for the front, but I think got 48 inches for the front. I hope this helps, I couldn't find my order in my e-mail.
The small lower plug is a weep hole. You want to fill the differential till the fluid starts to ooze out of it.
That being said, you also NEED to remove the plug on TOP of the housing near the pinion and add fluid there as well. I typically start there and add in close to a quart, reinstall the bolt and then finish up through the main fill port. If you have an ARB, I would recommend you use a heavy weight dino. Do NOT use synthetic as it will ruin the ARB o-ring.
Thats what was reccomend to me. Lock the hubs, keep in 2 wd. Do 65 or less first 100 miles, then have at it for the next 400...On my pro rock 60 in the front. Do I need to drive with my front hubs engaged to break in the gears? I don't think it's been driven much with them engaged. And I thought maybe I should do that to heat them up, then change they gear oil.
Sent from my SM-G900P using WAYALIFE mobile app
Just upgraded to new stainless steel ARB lines. These seem pretty cool compared to what came off. I've never ran ARB so I'm excited to try them out. View attachment 248610View attachment 248611
I'm going to order these. Don't think the blue line will last with salty roads.
Great, thanks for the good info. That's what I was thinking, but just wanted to make sure.
I should note that unless you're planning on doing any wheeling and by doing so, applying pressure on your gears, they will not do a whole lot of anything in terms of breaking in. I guarantee you that you can drive with your hubs locked for a couple of thousand miles and your gear oil will still come out looking like new. That is not to say that you shouldn't do this, just that it shouldn't concern you when you drain your diff and it still looks clear and golden :crazyeyes:
So just making sure I understand correctly. Are you saying there's not much break in going on in the front on the road with the hubs locked. And there's more break in on the trail. That's the way I understood what you said.
when are you going to get this thing out on the trails? looking forward to seeing it be put to use!
I saw a few posts back someone mentioned 4wp recommending dino oil for break in and synthetic oil afterwards. To be clear, you do not want to put synthetic oil in axles with ARB lockers. It will break down and deteriorate the rubber diaphragm in the lockers. Dino oil only.
Edit: I saw Eddie already mentioned this as well. Didn't see that post at first.
