Primo82
I cannot imagine tracing down a short in something as complex as a modern Jeep. I've tracked down electrical gremlins in a motorcycle before. Pulled the entire loom off the bike, opened it up, and inspected every single damn strand of wire. Third pass through found a slightly worn spot that barely showed metal. Taped it up and bikes run great since.
I've sold 2 other vehicles that had intermittent shorts. Just didn't have the energy or care enough to try to fix it. Junked the cars.
Sounds like your current mechanic is lost IMO. I would think someone with experience with Jeep and tracing these problems should be able to isolate the usual suspects to figure out what is causing your issues. If they aren't doing that then they are just throwing stones hoping to hit something. Granted I wouldn't trust a dealership with it either.
Wish I knew more about Jeeps electrical and you were a little closer. I'd probably start by pulling the loom and giving it a thorough inspection for wear, if it's worn open it up and look at the wire cladding. From there isolate what you can to still run the jeep. You can even potentially use a DC generator to power some of the components to make sure they're not tripping (well, I'm not sure if this is possible with canbus or if they sense the components aren't getting power...).
Good luck man!
Good luck man!
