Moochie
You guys really are the best :thumb:
At the risk of saying I told you so - I told you should have gone to Motech a long time ago :yup:
I'm sure glad I'm there now!!! [emoji851]
Maybe the shop didn't want to drop the transfer case lower to get to the sensor. It was laying on top of the case. We lowered the transmission down to get enough clearance to install the sensor. We checked the sensor as well and it worked perfectly.The new sensor,I had a shop install, was done incorrectly? It's awesome that you figured it out! [emoji106][emoji106][emoji106][emoji106]
I will be giving Moby a full performance tune. I will see what extra power I can get out of it along with getting a better performing transmission shift pattern. I will make a short video of what this process involves. I'll do a before and after comparison.
He told me they lowered the case to remove the old one and replace with the new sensor. WTF?
You already running the V8 or there to have one installed?..I remember you talking about having that done.
I have a 5.3 V8. Swap was done back in 2013. Turn Key Engine Supply installed it using Motech's hardware. Turn Key was recommended to me (by Motech) at the time because Turn Key guarantees that it will pass California's emissions requirements.
How do you like it? And how long did they take? Because I'm considering either a LS or Hemi but don't know much about the swap.
Haha I guess I'm a little slow.I have a 5.3 V8. Swap was done back in 2013. Turn Key Engine Supply installed it using Motech's hardware. Turn Key was recommended to me (by Motech) at the time because Turn Key guarantees that it will pass California's emissions requirements.
I love it! The 5.3 works great for what I need. I'm never going larger than 37s. With 40s, the 6.2 would be a better choice. It took about a month to do. I don't think Turn Key does swaps anymore though. Motech is making it easier than ever to swap in an LS engine! New improvements to their kit are happening as we speak.
Didn't know you had a 5.3 moochie. I thought you had a 5.7. Well good to know cause I was thinking a 5.7 for knuckles but might have to consider a 5.3 again. What trans do you have it paired with? Your still running a stock t case correct?
