Found out today that the noise is not related to the driveline angle. So moved caster up to about 7 currently. If I were to redo this swap, I would order the axle with extra built-in caster to optimize everything.
I am getting ready to do this same swap into my WJ and I have re-read your write up about 6 times.
When you say you'd have extra caster built in are you referring to the coil bracket angle because to change caster the C's would have to be re-welded on at a different angle. The Clayton kit calls for bracket angle of 6.50*. How much extra do you think it needs?
Also, when it comes to the drag link, I was going to use the same DL and bolt it up to the factor pitman arm. Were you suggesting that the factory pitman needed to be reamed for the new DL? What a bout a new insert instead?
Anything else you'd suggest that you'd do differently?
Thank you,
Chad.
