AZDIESELPIG
I was being the ass but clearly YOUR feelings got hurt, enough to post up all the scratches on your Jeep to prove how badass you are.
No sir just wanted to show you how silly you are....but keep talking....its working.
Hey guys, just wanted to get other people's opinions on how I could get my Jeep to ride smoother and closer to factory built.
I have a 2021 Jeep Wrangler Unlimited Sahara with modifications:
4" zone lift kit
35" BF Goodrich TA
Teraflex spacer 0.5"
Fox Steering stabilizer
Once I did all these modifications, my ride quality just got worse and feels too tough to ride on. I got too much sway when I turn, and its just too uncomfortable to drive.
I have a 3.5" TeraFlex Alpine Long Arm and it rides great - with Falcon 2.0 shocks.
I do not really notice much difference over the stock ride - I did test it on the freeway at 90mph on 37s and was really impressed how it handled and rode -
I know this is not a Teraflex site - but let be honest - they make a quality product. I had their lift on my JK as well.
Also thinking of getting:
Adjustable control arms
Front/Rear track bars
Steering tie rod/drag link/steering stabilizer
Control arm drop brackets
hopefully this will fix some geometry due to the lift which made it un drivable
I don't recall ever being hung up on the rear control arm brackets on my JK - not sure if the design is the same on the long arm now vs Teraflex long arm circa 2013.I see people get hung up on that rear control arm bracket all the time. I don't get why they don't move it up like evo and others have done.
I didn't seem to have an issue on the JL with the control arm brackets - approach angle with the stock bumper was an issue however LOL.
I have only hit Lower and upper Ajax in Florence Az with the JL but there are some additional trails I want to do once I have my rock sliders delivered from Artec Industries ( gotta support those Southern Az startups...now in Utah I guess). The stock sliders seem to like to trap rocks between the slider and the body which is bad....leaves marks!
I did look at EVO and others. I think I just stuck with what I knew and was familiar with and it works for me in the past.
If you are unable to drive your Jeep due to all the stability problems do you think you might give it away to a forum member who may be able to remediate it's problems and actually drive it?Completely ignorant.
Having the ground clearance is amazing! I’ll probably just install some front control arm drop brackets tbh!If you drop the lift height to something reasonable for that tire size you won't need any of that.
Do you think I should re-gear for 35’s?For 35s or 37s I'd be running 2.5 or 3 at the most. While I was waiting for coilovers and axles my Jeep was running a 2.5" spacer lift. Rode similar to stock and performed well off road.
How about a Teraflex lift kit?If you move to a 2-2.5" lift you shouldn't need any of those other parts.
Judging from this list, it would be cheaper to change out the lift and get something like the Synergy or Rancho 2" starter lift if you still have the factory shocks - the Rancho kit includes shocks
check this out:
I've owned TF parts, they have great marketing and upfront sales support but in my experiences with TF, their support after the sale sucks donkey dicks. Their parts are hit and miss, I've had some that worked and lasted, others that must have been made in some remote part of China with the cheapest materials that didn't last. Can't speak to their more recent products but it's your money, buy what you feel fits your needs.How about a Teraflex lift kit?
With a 4" lift, you're on the cut where a draglink flip and trackbar relocation can be beneficial. When you hit a bump with the trackbar and draglink at a steeper angle than stock, the effects are bump steer and side movement of the vehicle when the right tire is deflected by a bump. Also, control arm relocation will help with the ride. Your shocks and springs will also contribute to the ride quality big time. While I've read on forums that ProComp springs have a soft ride, I have no firsthand experience with them. But they don't have a reputation for great products. Mostly rebranded products IMO.What else would you upgrade once a lift kit is installed?
Track bar relocation bracket?With a 4" lift, you're on the cut where a draglink flip and trackbar relocation can be beneficial. When you hit a bump with the trackbar and draglink at a steeper angle than stock, the effects are bump steer and side movement of the vehicle when the right tire is deflected by a bump. Also, control arm relocation will help with the ride. Your shocks and springs will also contribute to the ride quality big time. While I've read on forums that ProComp springs have a soft ride, I have no firsthand experience with them. But they don't have a reputation for great products. Mostly rebranded products IMO.
So basically it’ll just change the angle of the track bar to come “close” to stock correct?
I think this is a good discussion on the front end of a Jeeps front suspension talking about how things should be. I used it to learn about the affects when I installed my lift.So basically it’ll just change the angle of the track bar to come “close” to stock correct?
