I’ll try airing down to see if that helps!I have 35" BFG KO2s when I did a chalk test to check for tread contact I found 27 psi to be perfect. 90% of time I'm on pavement.
So would having a softer sidewall kind of fix the problem? I have a sidewall rating E.^^^^ This
Factory Jeep recommend tire pressure is way higher than needed for safe operation on most tires. They do this for fuel efficiency reasons and their EPA compliance requirements.
Also a lot of the oversized tires are 8-10 ply rated truck tires and usually have a stiffer sidewall.
letting a little air out will allow them to absorb more shock.
Also thinking of getting:
Adjustable control arms
Front/Rear track bars
Steering tie rod/drag link/steering stabilizer
Control arm drop brackets
hopefully this will fix some geometry due to the lift which made it un drivable![]()
What else would you upgrade once a lift kit is installed?I'd fix the ride before throwing more money at it.
If you move to a 2-2.5" lift you shouldn't need any of those other parts.What else would you upgrade once a lift kit is installed?
Judging from this list, it would be cheaper to change out the lift and get something like the Synergy or Rancho 2" starter lift if you still have the factory shocks - the Rancho kit includes shocksAlso thinking of getting:
check this out:
Do you also do no offroading at all?
Completely a pavement princess!
Just joking dude. That is pretty funny you dug into your camera roll for all the scratches though.I do take it off road and hit the rocks.....in fact the factory bumpers were replaced after the maiden voyage trip (10 days in to ownership) to do a shake down run after the new tires and lift.....
Come on FAN BOYS do not be such haters - I mean you don't have to be douchey all the time!! Is it because I have an XJ too?
Carry on....
We’ll see how long you last here.Well, I have to say I thought it was funny you were talking shit.....do you even have lockers? And Rancho - come on bro....do better...fan boy
Aww did your feelings get hurt? DId you report me?We’ll see how long you last here.
Report you to who? Myself?Aww did your feelings get hurt? DId you report me?![]()
ahhh your one of those guys..I get it...Report you to who? Myself?
I was being the ass but clearly YOUR feelings got hurt, enough to post up all the scratches on your Jeep to prove how badass you are.Aww did your feelings get hurt? DId you report me?
I dont think I was being the ass...but whatever...
