duktrx
I hacked up the original connectors, cleaned up the cable ends, and tightened them down in the cable clamp part of the connector; I used lock-tight on those screws.Thank you for letting me know. I saw those over and over again in my searching and was concerned on the quick connect aspect...seems like it may be cheap, but good to know it's holding up good. I suppose the fact you can always spin them again to tighten them more as long as the threads don't wear out is a positive.
I went a slightly diffrerent direction for now, but I may still try that. I'm having to hack up the main vehicle wiring terminal now, which is a bit scary. I bought terminals that are one post and then I'm using the 3 post shim from the original harness - it seems like it's going to work but I won't know until later today after I'm done hacking everything up.
What did you do for your main vehicle terminals - did you cut them? Would love to see a pic.
I would take a picture, but my Jeep is in the shop for a regear and rear locker install. It only took four months for the parts to arrive.
