Okay, that helps a lot as a 2-door presents itself with a lot more to address. First and foremost, suspension geometry. If you really want to run 3.5" or more, I personally would recommend installing a long arm system. Without it, your short wheel base and the steep angles your factory length arms will be sitting at will provide a less than stellar ride ON PAVEMENT. Second, you really need to budget in aftermarket front and especially rear drive shafts. The rear is way too short and both will have the CV boots sitting in a constant state of pinch. This will cause them to fail very quickly. In any case, a long arm kit will come VERY COMPLETE.
