silverbackjk
:cheesy: I was talking with drew@ORE this past weekend and said the same thing. His opinion was not to do the rocker skins but the rear skins.
I would agree with drew. If i could only get one it would be the rear skins.
hmm, maybe ill just call today and see how long it would take to get them since I know once I get the sliders at my house ill want to install right away.
nice ! rear or rocker?
Rocker for now, rear will happen soon enough im sure, then I just need to make myself not order the tire carrier along with them.
Cool. Yeah good luck with that, how do you get the rear skins and NOT the carrier![]()
Im basically looking for like 1" to kind of recenter the rear wheel in the wheel well. Ideally id like to just do an 8" stretch....but thats a long way off.
What I would do since you weld your own stuff is get the control arms like Overlander said and at the same time recenter the wheel in the wheel well and also correct the pinion angle, then grind off the lower coil perches and weld new ones in the right spot
