Sun started shining here in Oregon, so outside jobs are keeping the project time limited. I was able to make a little progress on the frame and bumper today though. The frame on this Jeep is amazingly thin. I thought the 10K Warn on the JK was quite ambitious for a frame that’s only .120 thick, so a 12K on a frame that’s .083 has me a bit worried. The winch wouldn’t fit between the pads on the end of the frame without affecting the bolt pattern so I removed them. Bent a couple of L-serts out of .120 because I didn’t want to manhandle the frame, just add strength to it. I drilled the frame in a crisscross pattern for plug welds on the side, and then every 4in on the bottom. You can also see in the pics how I trimmed the frame to expose the L-sert 3/16, so that when I weld it to the frame endplate, everything gets tied in. Here’s how that turned out.
