Gladys
Bizcuit
I’m currently waiting on parts but there’s plenty to do so I’m going to start with bed . My last Jeep was a Wrangler and I didn’t care for the tire hanging off of the back, and with the Gladiator I think there’s too much overhang. So I’m hoping to get a compromise in this project. I’d like to post some pics in hopes of keeping me on track to my May finish line. So here goes.
Here’s the first fit. I shortened as much as I could but wanted to retain the stock appearance of the beds interior.
Got the front axle out to start removing the brackets. The Apex tie rod ends look big, even on the 60. Also cleared the frame of all the brackets.
Bending up the strut hoops now. I printed some ends that I think will look good and simplify the process. I printed them in 5 degree increments to make up the difference in angles on the frame. Once I’ve figured out which ones I need, I’ll machine them out of steel. 5 degrees on the front, and 15 on the back of the hoop work for the front axle.
Working on the LCA brackets now. This is the shape required to clear the DPF. I was going to delete just to get more room, but I was able to make them fit.
As you can see, I’m going to be running a three link. Bolted them together to keep them from warping while welding.
Working out the kinks of the strut hoops today. Not as happy with these as I thought I would be. The front mount point lines right up with the coil relief in the frame. I could cut it out and replace it with a flat piece, but I don’t think the juice is worth the squeeze. I also think I need to get them to be taller which would require moving the ABS and the battery.
Here’s my next best guess. Because of the boxy design, it achieves the additional height I think is needed. And covers a smaller footprint on the frame, staying away from the old coil area.
Looks good 👍 I like it better than the hoop stronger I’m guessing as well.
