Gears?
Cool, now since the gearing is out of the way, brands............and price
Gears only done by a shop could be around 1500 more or less.....
I regeared to 4.56 both axles, air lockers on both plus sleeved and gusseted the front D30 and it was 3400 out the door
If you have a D30 I would rethink the 5.13's in it. The R&P is super tiny with a 5.13 in a D30. 4.88's will be good and the R&P is a bit bigger.
:eek: You could have had a PR44 in the front for just a bit more then that.
OUCH!!! :eek:
yea im only trying to do gears on both and upgrade the front shaft to a chromoly for the D30 (per eddies advice in the noob post)
Maybe Eddie will chime in on this one and give a little insite for those of use with D30 front and D44 rear's. want to make sure i get it right when the time comes. his choice of brands, what all is needed, good C gussets to throw on, etc etc.
for 35 and such with the 3.8 you want to get the power back. 4.88 will get you to stock but 5.13 will get you some more power but less top end speed. that's all up to you to decide what you want. 5.13 is the max you can really go before you start breaking things like the one guy said. when it comes to gear brands they are all pretty much Chinese made from what I've heard and there's not a big difference in brands. But Cs always go with the evos
I got a reputable jeep place out here in pa charging 300 and axel. not to bad in my opinion
Im not trying to hitch hike this thread but does anyone know a place around San Diego that would do a gear reduction for a decent price? :confused:
I would drive to EVO in Fullerton. $999 for gears and install. I don't think you could find it cheaper anywhere else. Even with the gas to get there.
