Unlimited4x4
I have an 05 LJ. I replaced the multifunction switch a few years ago and all was fine. Recently the fogs stopped working again. I swapped fuses and relays and after those were eliminated figured it was the multifunction switch again. Just put the switch in and nada. I need to put a meter on some connections to see if I have power. But has anyone had this happen? The only item I have not swapped is the multifunction relay on the unit. But I think if that failed other lights would not work. But all other lights function normally. Any input would be appreciated.
thanks
thanks
