NUBS MCGEE
they turned out good. nice job:thumb:
So as I said in a previous post. I drilled a 1/2 hole (for the side marker light) in the wrong hole (fender moulding clip hole) meaning the hole is slightly bigger then the moulding clip. It's not noticeable to anyone except me and if it were an interior hole I wouldn't even care but its the first one by the headlight. There isn't any movement unless I take it and pull the flare away and it just slides right out. So the question is best way to remedy this issue for a tighter fit? I could use silicone? I could just tape behind it (which is how it is now) or if anyone knows maybe use a larger moulding clip (part number if you know)? Ideas?
For people who have done the rear. Would you recommend taking the fender flares off or leave them on. There is no substructure but to fight on the rears but there is the liner. So I'm unsure if I should take them off or just slice thru them and cut with them on?
Looks good! I need to put that angle on mine too. :thumb:
Thanks Overlander!
Now next question for someone is…this aluminum heat shield looking material under the front wheel wells. Not sure what to do with it…its definitely not the best looking but I'm not removing it if it needs to be there.
Thanks Overlander!
Trim your liners and put them back on. My stay on fine and don't rattle or hardly move.
Sorry I was referring to your front liners. Think you has said something bout seeing all the engine stuff.
