SaddleTramp
You have king bumps, so it's a bit different.
10-4, sorry, I need to stay in my lane , thought the extension blocks would be the same regardless if stock rubber bumps or air bumps are used.
My EVO bolt-ons are arriving today, reading about the install has been really informative. What control arms are y'all running with this kit?
I'm driving with currie arms. :thumbup:
Question: if you guys only had the money to buy either the front or the rear bolt on's due to finances which one would you choose first?
Neither. I'd put my money to more pressing uses. That's just my :twocents:
Edit: That's probably not what you wanted to hear. I'd do front first then rears.
Running Currie front lower control arms on my rig.
The first thing I'd recommend with anyone installing this list at home, don't get overwhelmed. Take your time and go step by step. The install is pretty straightforward.
Post pics after you get them installed!
How's the EVO + MC combo working for you? I'm torn between MC arms or long arms....I'm running metal cloak arms.
Have fun with the install! I'm still waiting for my front but did the rears a couple days ago.
It's no "quick n easy slap em in job". If you have a lift it will be 100x's easier/quicker.
I did the rears in about 6hrs rolling around on the floor. Instructions aren't all that great, the pics Mechengineer2 dude posted on JKF are a nice reference point. And you'll find out quickly some things need to be done in a certain order for it all to go together right.
My .02... Remove the calipers to make room to cut for the rockstars, and don't put them back on till AFTER you put the new brake line on the caliper.
And don't tighten up the hardware on top of the CO till it's bolted to the frame. And don't tighten the body mounts on the upper supports till you have the coilovers in so the longer bolts line up thru the top.
Good luck!
I've gathered a lot of install info about the EVO bolt-ons in threads like this and your comments about the kit are consistent with others. Fortunately, my JK isn't my DD, so I can be meticulous about the install. Thanks for sharing the additional details, much appreciated!
Do these coil overs come charged or do you need to take them to a shop to get some nitrogen?
They are charged.
Uhh honestly I don't know yet lol, still sittin on jack stands waiting for the front C/o's and my ProRock.
I've got kind of a bastard lift deal goin on in the rear of this thing... MC arms, Full Traction CRC link & Evo Bolt on's.
So far it cycles smooth when I pulled the springs so I guess well see what happens!
