L bracket that attaches to the brakeline bracket
Mine have only one clamp at the top of the reservoir.
Ok I have mine like moochie. I need to go look to see if I have this l bracket.
well then they will continue to make the noise and have extra bow in them.
Yup found them. Thanks for the help. Will get them installed. I need to adjust the stop rings, so will get it all done.
Mine were installed at ORE. I have no other brackets to mount the reservoirs.
And this is supposed to be normal? It took out a lot of the bow by tightening them up. It's at about 3" of lift currently .
The other bracket may have been an idea added after your install. You have had yours awhile![]()
Sent from my LG-D800 using WAYALIFE mobile app
Mine are rock solid the way they are.
Make sure you adjust the two silver timing rings are about a half inch above the slider. That should quiet them down.
NO! as i said, you need to add preload to the coil-over. you have them set too low and they are not designed for that. proper setup is important to ensure the coil-over is working properly. 3.5" of lift is about as low as they can be set and still function properly.
but they are yours, so you can run them any way you want to.
What is the best way to go about this? Mine need adjusted down a good distance.
Sent from my SCH-I605
Anyone have an instructions for the rear coilovers? They are on the way and I would like to check em out before they get here.
Here you go... I will leave it there for a few days then remove it so EVO doesn't have old versions hanging around. Mine here is already over a year old.
http://www.davechewphotography.com/temp_images/EVO 1107 rear bolt on coilover.pdf
Dave
