To be honest I looked at this write up, up and down to make sure I was accomplishing the flip properly. However I did not re-use the factory bolt as said on the write up on Chris's write up. I ended up going over to Lowes and buying a bolt 10M-1.50 x 100 ($1.66 at Lowes) which worked perfectly. I also used this Youtube video.
http://www.youtube.com/watch?v=zB056ZbhOG0
Which prompted me to flip the sway bar the other direction and cut away the plastic. I truly appreciate Chris's write-up and truly appreciate him taking the time to write this up but I think this is safer personally. The connector is no facing the ground, which bring the connector facing up with no way of harm. And from connector down, compared to up, it was a couple inches difference in clearance. With my setup the sway bar hangs down from the EVO front bumper a good 1". However it's harder to get to if you need to get to the connector.
