that's a smart and much easier way to do it if the stud is stuck, also seems like there's no need to remove the set screws using this method.
Once I got my calm brain in place I saw the circle clip, removed it and the stud dropped out.
I won't put the ball joint back in though, the top of the stud and inside of the cap look like they've made contact and both surfaces are rough to the touch.
I'm sure me trying to press the "cap" off didn't help. :doh::doh::doh:
So after seeing how the lower is actually done, time wise it may be quicker. You do need to let the cement for the lower seal cure for the 3 hours before greasing where pressing in new joints it's grease and go.
mileage wise, I got about 55k+ miles out if them, which is better than OEM style joints since running 37's on beadlocks
