Okay now that you guys all kissed and made up, I have a serious question. Where do you guys find that gear conversion table/calculator?
You can go here also:
http://www.4lo.com/calc/gearratio.php
Need some advice please: My budget won't yet allow me to regear my 2012 auto JKU w/ 3.73's, but I want to skip the 35's and go 37's. Here is what I plan on doing:
37 Toyo OC or Nitto Trailgrapplers
3.5 Metalcloak ARB lift
Chopped fenders
C gusset and sleeve the D30
Living in AZ and not doing any rock crawling, but some normal trails, can I wait to regear for about 6 months? Been stressing about this for weeks on end so any help appreciated.
I wouldn't do it. It'll be searching for gears a lot. I would wait until you save up some more.
Those who has done the 5:13 regear on their 3.6, what RPM are you sitting at on about 70 to 75mph
35's and 5.13 at 70 sits right around 2800-3000 for me. Keeping it between 60-65 seems to be a sweet spot.
Thanks man, sorry should have mentioned I am on 37s, I see the calculator works it out to around 2800. That's not too bad I reacon I can do 65mph![]()
Yeah that's too high for me, so I'll be doing 4.88's on 37's.
Hmmmm :thinking: maybe that is the way to go, what RPM you sitting on when you doing 70-75mph with the 4:88s
Yup, trying to decide this myself. Seems like 4.88 would be better for DD, 5.13 better for wheeling. Mine is a DD now, but no longer a DD when I pay it off in a few years.
what the deuce! I have been reading what is recommended to be done from everyone's experiences and I have learned that when lifting and going to bigger tires new ds/s are highly recommended. from reading all this it looks like most of all the questions are either for an automatic or for running 37's. so I guess now my question is, having bought a new 14 jk sport 2dr with the 6sp, I bought and waiting for the 3in enforcer kit and got the 1310's to replace the stock ones, with the procal to reprogram and exhaust spacer kit(which Northridge is awesome and used my wayalife 10% !!). and will be running 315's on 17 alloys. what would be better recommended for a manual? would it be who of me to go out and get the 4.88's? this is my DD and my weekend trail runner.craziness!
2014, JKUR, 3.6 auto, 37's and 5.13's, running about 2700-2750 revs at 70mph. Love the 5.13's, seems to keep me in OD more than not at highway speed, no gear searching.
Being that you have a 14 and a 2-door, you will not only need to address your front drive shaft, but your rear as well. Exhaust spacers are totally unnecessary as your new front shaft will be narrow enough that they will not be needed. I would return them. With 3" of lift or more, your factory rear shaft will sit in a constant state of pinch and that will lead to premature joint failure. Before that happens, you will see grease spitting out from the CV boots. At that time, you really should replace the rear shaft as well and when you do, you will need adjustable rear upper control arms to set your rear pinion angle. Being that you are getting an Enforcer kit, I would recommend getting a set of Currier rear upper arms as they are a good match. As far as gear ratio goes, 4.88 should do the trick with 37's on a manual but, I personally might still go with 5.13's just to get a bit more power.
