pvanweelden
Yes, just like your diagram showed. No need to tie into both, they are on the same circuit. you just need a trigger to turn on your led's thru the relay.So can I run both lights tapping into one reverse light?
Okay, so I want to tap into the wire that goes to the switch, but I'm running dual light switches, does that make a difference? Also, where do the diodes go inline?
Thanks guys, I appreciate the help. I'm one of those that measures twice and cuts first but it doesn't always work out. I like to make sure I completely understand and now with the drawing I do.
I figured if I could make the DIY Spod I would be able to get this too and it seems pretty straight forward now.
Glad it helped!
It doesnt get much simpler than this. Yes the diodes go inline. As stated earlier by pvanweelden when you put it in reverse all of the lites will come on. If you want just your Aux lites on then turn on whatever switch you have connected them to on your DIY Spod. Hope this helps. Sorry Darknight, I was drawing this up as you made your last post.:thumb:
I hope pvanweelden doesn't mind but it's in keeping with his great thread here that I also did a starter solenoid mod to my winch. I'd like to add to his thread how I did that.
I next ran the starter size wire from the alternator to the solenoid mounted earlier:
View attachment 65604View attachment 65605
Finally I attached the winch line to the solenoid with the 300amp fuse I had earlier.
Running the 14 gauge wire from the Bussman relay/fuse box to there was a breeze and now my Winch switch on the cabin Daystar panel operates the large solenoid providing ample power to my winch and ample fusing.
I probably will go with a circuit breaker later for the winch line but for now this has worked well.
Cheers!
Wait, I think I got it now. #2 will get the power from the outlet source or cigarette lighter and #3 will get the wire from the starter solenoid. If that's not right, I'll advise.
^ awesome job!
Thanks man just got most of Youngfires installed today under my build, just have to do her switches and heated seats and should be all done!
You'll be done when her thinks it's looks good too lol
don't understand but totally agree! :clap2:
looks great Andrew!
