No problem. Good luck. It might not be the cause but was for whatever wobble I had. I couldn't drive over 35-40mph without my jeep shaking to the point of it feeling like it's falling apart. I was about 2/8 or 3/8 too much toe in and now I drive without my steering stabilizer and love it.Thank you for sharing the link its something I'm gonna look into next, along with my C's.
Hopefully when I get some time I'm gonna try and take some good pics so everybody can see what I'm seeing maybe that'll bring about some more input.
Yea definitely. Thats even worse than mine. Just get it to a difference of 1/8 and you'll be good.So I checked my toe in and toe out and this is what I got.
Front of tires= 67”
Back of tires= 67 1/2”
So gotta fix that for sure
As you said, ride is subjective... I'm sure no one will dispute that Kings are the "best" but it really depends on what you're doing.So along with our little girl coming to the world last week and becoming a Daddy.
Loving it by the way can’t believe we have our own little Wayalifer to raise.
I’ve been thinking about what shock upgrade I wanted to do for D-day.
Money isn’t an option I’m willing to wait and save cause it’s worth saving for the best.
So I’m stuck between
King 2.0s
Fox 2.0s with or without reservoir and the
Rancho 9000xl
I know that ride quality is completely subjective so all I’m looking for is everybody’s experiences
Thank you in advance
King 2.0s
Rancho 9000xl
The adjustability really helps in the 2 door. It's nice to be able to tune for weight and terrain.David, congratulations! You will get to sleep again next year... ok a couple months. Anyway I run Fox shocks and to be completely honest they are stiff if your just putting around. The faster you go the softer they get. But I have a 2 door that doesn’t ride as well as a 4 door to begin with either.
Personally, I've been really happy with my 9000XLs, but if I had the cash, I'd probably get adjustable Kings.
So after many attempts to correct my toe D-day my tie rod adjuster piece will not budge loose after being soaked in wd40 and PB blaster I don’t know what to do but put a pipe wrench on it
Factory is adjustable. They just rust and seize up quickly. Best thing is to use some heat on it honestly especially if it gets so stuck that pb doesn’t work. If you wanna keep trying the pb make sure you take a huge hammer to it as well to try and break the rust free then use the giant pipe for extra leverage. If all else fails, heat the bitch up
Mine was hard to turn also. I used a vice grip and a lot of pb blaster and it eventually turned. I had a stabilizer bracket on that end of the tie rod that I had to remove also because it was preventing it from moving, but you won't have that unless you have a dual stabilizer.So after many attempts to correct my toe D-day my tie rod adjuster piece will not budge loose after being soaked in wd40 and PB blaster I don’t know what to do but put a pipe wrench on it
