Appreciate it man. Hopefully Ill be driving it by the beginning of January.
I was waiting on that comment from you lol. Told ya once I got back from Daytona Im gettin it done.
Appreciate it
Will do here shortly.
What else do you plan on doing to it between now and January? Sorry, didn't dig through the whole thread beyond the past few months.
So question, are the struts currently not pressurized? If they are where is ride height? How do you keep the struts from bottoming out or is the bump stop built into it?
They are not pressurized yet. Ride height is fully adjustable depending on what pressure you run. There are 2 resis in them and 1 is basically what determines the quality of ride and other is basically ride height. Im guessing it will be 4" or so higher but im just gonna play with pressure till I get it the way I like it. I want it to be as low as possible but still have enough stroke left in the ORI so it isnt a very harsh ride. Lastly struts have internal bumpstops. What most people dont realize is even though it is advertised as a certain amount of travel there is actually a inch of that the bump stop is taking up.
Ah ok makes sense. So your full bump now will still be the same once pressurized because your on the bump stops as it is. Makes sense.
Very nice. I was wondering the same thing regarding the bump stops. Good info.
I was also curious about the bump stops thanks for the explanation! Curious if you are going to use a sway bar? I've heard with struts you don't have to run one but haven't found a forsure answer!
Damn!! That tower looks really well done. Fab looks good
Im sure this is hard to believe but finish mounting up the last strut. Here is some of the pictures of cutting it up and finally welded to the frame. The towers ended up within .5 degrees of each other so im happy with that.
View attachment 200470View attachment 200471View attachment 200472View attachment 200473
Lastly here are pictures of full bump and full droop.
View attachment 200474View attachment 200475View attachment 200476View attachment 200477View attachment 200478View attachment 200479View attachment 200480View attachment 200481
Also Im considering pulling Poison Spyder cage out if there is any interest in it. I also have the c pillar kit (never used) and Rock Hard harness bar to go with it.
Man, your rig is looking badass! Very curious to see how those ORI's perform for you. That's some damn good articulation!
Build is going nicely! Love the seats!
Have you had to clearance the gas tank for the sterling? We've got two sterling installs going on at the shop I use and having major issues with the Sterling impacting the gas tank under flex. Ride height it fits fine but as soon as we try to flex it and the passenger side goes up and driver starts drooping the trackbar pulls it into the gas tank. All the pinion reinforcement has been cut away and it's still hitting there and the ujoints. One guy bought a 2door tank and that is NOT a fix. The tank's fill neck is in the same spot so it ends up being shorter in front, not the rear where it is needed.
Thanks!
You should lift the driver front with a fork lift and see what happens with the rear tank clearance. That's the scenario that makes it the worst it seems. If you've got it cleared maybe we just need to massage the tank in more. Only other things I can guess would be how much lift you ended up with and how much stretch to see if it helps.
I know with my RK arms in the rear its back a 1-2". I figured worst case it will self clearance. We will see what happens. If i gets to where I cant stand it Ill put a fuel cell in it.
Normally I'd agree but I'm not sure I can take solace in my gas tank self clearancing. Sounds like a recipe for a spill / fire / bad day.
