Thank youNice build! This is starting to get good.... :clap2:
Thanks man. It was the best way I could think of to get it off.Cool to see it hanging on the hoist.
Cut some of the frame off, some more might need to go depending on where the new control arm brackets go. More of the tub is going to get cut as well I'm rethinking my transfer case, not sure I like how much it's clocked. I'm really thinking about springing for an atlas.
Grab as many as you want, I need more space in my garage.Looks like I need to come over and grab some parts now.
Unfortunately I chose one of the shortest CJs. I'm going to stretch the wheel base to 110", most if not all will be in the rear. I want the Atlas so it will raise my front yoke and give me more clearance for the belly skid plate and it's an Atlas.Problem with the old CJs is they are so short.
Another transfer case may not fit due to length issues and where your rear axle ends up. Atlas is nice and strong
Also, where are you getting your fabrication parts?
No, it's going to be a tube chassis with the frame as somewhere to start from. I'm using 2" X .120 wall DOMYou worried about that old frame holding up to the big axles and tires?
I broke the frame on my old CJ5 in 1989. That metal has aged a bit since then
