MericaMade
Assuming that’s a double cardan drive shaft, then yes the pinion angle and driveshaft angle should be the same. Ten degrees is too much caster anyway. Try something like 5 or 6. You have the PR44 with a extra caster, right?
Yes it a Adams 1350 double cardan and yes I got the unlimited PR44. I went off the Evo arm specs I posted above and the bump stop angles and pinon just didn't look right to me. Thanks Fiend, I appreciate the help.
