Big Bad Wolf
Part 4 - Removal of engine/tranny and components.
At this point it's time to strip what is left.
First was the exhaust system. The bolts holding the pipes to the manifolds were seized BAD, I had to cut them off. During the cutting I glazed a manifold and put a slight hole in it :grayno: I will have to fill the hole or purchase a set of aftermarket manifolds. I do plan on doing an engine swap but I may put some wear on my V6 first. Where I live would be hard to sell it so I might as well use it. It's a set of 60's or an engine swap.. In my mind 60's come first.
Second was the engine. I decided to leave the transmission attached but my hoist would not go high enough to clear so I had to muscle the tranny over. My hoist is a pain because the front wheels do not rotate so maneuvering was insane. If I had a larger work area it would be no big deal but when you back over a concrete lip with that much weight pushing it back over is not fun.
The rest I didn't take photos of, I just got carried away with work vs taking pictures. I will try to add further photos.
My fuel tank was half full so it was heavy. I decided to use two ratchet straps for safety and used a motorcycle lift to take the weight and role it out. I will note I HAD to get someone to help carry the tank out of the garage.
The steering box was removed and getting the drag link off the pitman arm was a PITA. I would not suggest heat here as it could travel to the box. In my case using a pickle fork did the job.
I used jack stands the whole time but had planned to create a swivel so I could rotate the frame to work on it. At one end I used an engine stand and the other I used wood to mount on with a hole with a sleeved bolt that could rotate.
Having ran out of oxygen for my torch I broke a couple rear sway bar bolts and one cross member bolt. I drilled them and used an easy out. Of course during the process I had drill bits breaking inside the bolt and even a broken easy out. I knew this could happen so I made sure to drill all the way through the bolt so I could access the hole from the top in case of an issue.
For reference there are nuts welded inside the frame for the bolts. From here I drilled a small hole in the top of the chassis above the lower bolt I had drilled through. I used a thin punch to slip down and knock the obstructions out of the bolt. It worked! PITA! SERIOUS LESSON here, don't get impatient and make sure to use a torch. This was my fault.
More photos to come here.
