benatc1
thanks! I missunderstood the relationship between the 2 angles and the added caster
Sent from my SM-G928V using WAYALIFE mobile app
nice, I appreciate you going to take a look! I'll take em from ya. I'm actually passing through Carson city tomorrow morning as we gotta run up to South lake quick. if your around I could swing by or else I can buzz down any evening this week. whatever works for you. thanks again!!Just went out to the garage and confirmed.
Watch WAYALIFE YouTube Videos
WAYALIFE Jeeps & Specs
it was funny, I actually got out of work a bit early and the Fed ex man was pulling up at the same time I wasMy Lord. You must have pitched your tent when that all came :shock:
yes it is, not sure where I want to start this weekend? thinking axles/diff change then corners and tire carrier being they will take the longest and have to go to the powder coater. plus I can waddle away at the other stuff throughout the weekThat's a lot of parts. :thumb:
I guess you could say that..[emoji16]So you pitched your tent when you saw your FedEx man [emoji23] I might have as well...
[emoji23] [emoji23] [emoji23]
gonna be alot better looking! may need to hey in touch with AJ again if he wants to make a little money and burn on those sliders!Good lord man! Im not even going to recognize it when your done
sent from my Illudium Q-36 Explosive Space Modulator
thanks man! the d ring mounts were a pain but I notched the crossmember just enough to get that flag nut in there and then it was easyLooking good :thumb:
yea i couldn't get mine to squeeze through the back but I was already cutting the front so what was a little more right! but true job is done and they aren't going anywhere. I may paint the heads of those bolts tho to make it blend more but idkI know what you mean. Same here. We put the flag nuts in from the underside of the cross-member. Not sure if we didn't fully understand the instructions or common sense eluded us, but we plasma cut the crossmember hole underneath to get the nuts in. It wasn't until we were completely done that we realized that they would have fit through the holes in the back. Oh well. Job is done.
