GCM 2
I have been looking for this "Hulk Hogan" outfit everywhere! Know where I could buy this thing? It's pretty sweet.
Having never done a set of ball joints before, those videos were super helpful. I followed along with a few exceptions:
- Not sure why he separated the hub from the axle. Just remove the three bolts holding the carrier to the hub and pull the axle and hub assembly out as one unit.
- I picked up the OTC Ball Joint Press along with the Dana adapter kit. Made for a super simple setup and saved a lot of time.
I might recommend taking a few pictures of everything before you pull it all apart. I spent a few minutes figuring out the orientation of the dust shield and a picture would have saved me a bit of time. Also, be very gentle with the speed sensors. You will have to pull the sensors out and they are prone to breakage.
Just a few pictures from my install (installed prior to lift):
Good luck and have fun with the install!
ERAU
I find mine at Hogan's-R-Us here I'm the whales vagina. Pretty cool store.
Um, did you install ball joints as soon as you brought your brand new Jeep home from the dealership? It doesn't look like there is so much as road dust on that thing!!
Hit with a mallet.
The dirt is not a big deal there are inner seals that protect the internals.
Those are not seals, they are guides to keep the shaft from knocking out the inner seals. Just leave them there and put the shaft back in when you are ready.
If you're referring to my pics, yup, it was brand new! I think it had 45mi on it! I knew the factory joints can be a weak link and I didn't want to have to pull everything back apart to change the ball joints after having it all apart for the lift install.
Need a little bit more help with the install. Trying to put the knuckle back on and I'm having trouble. Dynatrac instructions say to tighten the upper ball joint but first to 35 ft lbs. I'm here and I can't seem to tighten the nut any more. I have easily exceeded 35 lbs or torque.
Pic for reference. Thanks in advance!
I could be wrong, haven't gotten mine on yet but I think that is how they look when on
Don't forget the little holder for the abs wire. That little metal bracket.
