that is not accurate. It’s the same motor from 2012-2018.5 when they stopped making the JK. It’s 285hp in all JK’s and even the 3.6L JL has 285hp.Get a 2015 or newer. They upgraded the 3.6 in 2015 with more torque and horsepower.
My mistake. It was 2016 they upgraded the 3.6, with horsepower rated between 285 and 305, dependent on which vehicle model it was installed in. In the Wrangler, the newer 3.6 is derated to 285.that is not accurate. It’s the same motor from 2012-2018.5 when they stopped making the JK. It’s 285hp in all JK’s and even the 3.6L JL has 285hp.
Again, not correct. The 3.6 in the JK and JL has had the same 285hp since the start. No upgrades in horsepower or torque have been made.My mistake. It was 2016 they upgraded the 3.6, with horsepower rated between 285 and 305, dependent on which vehicle model it was installed in. In the Wrangler, the newer 3.6 is derated to 285.
In 2016, the 3.6 was given a two stage Variable Valve Lift system and the VVT recalibrated. Compression was changed from 10.2:1 to 11.3:1. The new version could deliver up to 305 hp. When installed in the Wrangler, the 3.6 was derated to 285 hp.Again, not correct. The 3.6 in the JK and JL has had the same 285hp since the start. No upgrades in horsepower or torque have been made.
It has the same horsepower. I would love to see these claims you state consider I have had two 2012’s and a 2017 and they are exactly the same. I also swapped a 2016 engine into my 2012 and it was the same.In 2016, the 3.6 was given a two stage Variable Valve Lift system and the VVT recalibrated. Compression was changed from 10.2:1 to 11.3:1. The new version could deliver up to 305 hp. When installed in the Wrangler, the 3.6 was derated to 285 hp.
He eventually said that the power (when installed in the Wrangler) is the same. So they did something tangible (or intangible) to be able to say 285 HP again. This might have been to avoid regulatory requirements.It has the same horsepower. I would love to see these claims you state consider I have had two 2012’s and a 2017 and they are exactly the same. I also swapped a 2016 engine into my 2012 and it was the same.
Says right in the article that the ungrades were for the grand Cherokee and Durango only.![]()
3.6L V6 VVT Pentastar Engine - In-Depth Look at Design and Reliability
What is the 3.6L V6 VVT Pentastar Engine? Is it good or bad? Read about Chrysler 3.6L V6 VVT Pentastar Engine design and features, its the most common problems and relaibility.www.motorreviewer.com
Yeah exactly. Who gives a shit about those. This is about a Jeep.Says right in the article that the ungrades were for the grand Cherokee and Durango only.
Just admit you are wrong. You realize the guy is talking about a wrangler correct?![]()
Small ECU firmware changes (e.g. change one number) can accomplish the minor reduction of power. Such changes would be 'intangible' to me.WTF
What 'intangible' thing can be done to an engine to take away 20 HP?
Lol, do you ever think about what you're saying or does shit just kinda blurt out and make it to the keyboard?
Tangible means things you can observe or measure such as engine bore, stroke, valve size, etc. Intangible would be things like firmware or default settings in the ECU, or elsewhere. Different vehicles get different firmware in order to optimize for vehicle specific things such as gearing, weight, and differences in intake and exhaust flow.WTF
It can be expensive to change parameters for a vehicle already in production due to a need to update documentation, redo tests, etc.
The manufacturer will always place a priority on model and fleet fuel economy since the feds regulate this and will apply penalties. By tweaking 'intangible' parameters, Jeep may be able to sell more units of a particular build configuration.
Surely this is obvious to everyone?
No he’s a computer engineer. My youngest son is as well, their brains work differently.You are retarded
Caught in my own hubris. While researching how to fix the 3.6 in my JK and what parts were needed, I was asked over and over what year I had because "it makes a difference as the engine was updated in 2016." My impression was the newer engine was derated and used in the 2016 and newer JKs. Instead, the JK got the YJ treatment.Just admit you are wrong. You realize the guy is talking about a wrangler correct?
