68' M715 AKA "Smokey", 8.1 engine on links, coils and 40's
Rebuilding the fender to fit the Accusump, using 16g plate
Just tacking it in place for now. Lower clamp mount is installed, I’ll finish the upper mount portion tomorrow
Fabbed up a quick mount for the Accusump solenoid out of some scrap aluminum. The solenoid will release up to 3 quarts of oil into the engine in the event of low oil pressure
Fully boxed and sanded
It tucks up between the coolant filter and clutch slave
And here’s the fully mounted Accusump. I’ve probably fitted the fender on/off 50+ times, hopefully won’t have to screw with it for a bit now.
It’s kind of a FrankenFender now, ha!
And here’s the pile of old bits. Quite a bit of original fender got chopped off
Amazing! Are you going to try to make the new fender area look old?
Well, unfortunately no. If the entire truck had looked like the engine bay area/inner fenders, I would have left it and enjoyed the patina but.....It had 3-4 coats of terrible brush paint all over it. Including a horrific orange. So, eventually it'll all get media blasted, primed and re-painted with a Rapco military paint
Finished out the rest of the USB plugs today
Also, this M715 never had grill of any sort, just a great gaping hole open to the radiator. Maybe the grill was lost years ago, who knows 🤷‍♂️ Wanting to avoid jamming a stick right through a very expensive radiator, I picked up some 316 stainless expanded metal. Then, I replaced the 5 factory sheet metal tabs with much heavier 1/8” units
Formed the expanded metal a bit with a sanding wheel, TIG welded some stainless 3/8-16 nuts on the backside and…
