Fabbed up a quick mount for the Accusump solenoid out of some scrap aluminum. The solenoid will release up to 3 quarts of oil into the engine in the event of low oil pressure
Fully boxed and sanded
It tucks up between the coolant filter and clutch slave
Well, unfortunately no. If the entire truck had looked like the engine bay area/inner fenders, I would have left it and enjoyed the patina but.....It had 3-4 coats of terrible brush paint all over it. Including a horrific orange. So, eventually it'll all get media blasted, primed and re-painted with a Rapco military paint
Not a ton of time for stuff today. Was able to layout spots for 3 USB/12V plugs on the lower portion of the dash. Drilled the holes and added 10-24 threaded nutserts
Also, this M715 never had grill of any sort, just a great gaping hole open to the radiator. Maybe the grill was lost years ago, who knows Wanting to avoid jamming a stick right through a very expensive radiator, I picked up some 316 stainless expanded metal. Then, I replaced the 5 factory sheet metal tabs with much heavier 1/8” units
Formed the expanded metal a bit with a sanding wheel, TIG welded some stainless 3/8-16 nuts on the backside and…
